Hey everyone i'm having a lot of trouble removing my pitman arm to finish installing the rest of my lift. Ive been soaking it in pb blaster for the last 4 days. The bottom nut is off but the arm itself isnt budging. I read that using a pickle fork on alternating sides then a pitman arm puller should work, but it hasnt. I called the local ford diesel master tech and he suggested the same thing. I really dont want to cut it off if possible, but i dont know what else to do. So far here is what i've tried and the results
-pickel fork and puller: broke the puller (bent it out around the arm and damaged the pullers bolt
-grinding the pickle fork down to increase the thickness before it hits the splines: deformation of the fork
-hiting the arm on both sides at once with metal hammars: Lots of noise, no movement
-hitting a flat head in over the fork: diggin into the metal of the fork, no gap increase
Any ideas? Winter is coming quick and i need my truck back on the road, the bike wont do too well in the snow. Thanks much, have a good one.
