1 - 2 of 2 Posts
2006 F-350 XLT 6.0 Standard Cab...
So I had an issue with my Check Engine light, and the small dealer replaced my instrument cluster with a used one. Everything works fine except for the fact that when I shut my car off and open the door, the aftermarket radio (that I installed, and which was working fine before the new cluster) doesn't shut off. I have to remove the face plate to shut off the radio, and even then I'm not sure if the radio is still active and sucking juice from my batteries. Also, the interior lights do not come on when I open my doors. They used to, now they don't. I can manually turn the interior light controller all the way up to turn them on, but they do not automatically turn on when the doors open.
Anyone have any clues as to the connection between a new, used IC and the electrical issues I'm having with the radio and interior lights?
Thank you!
Administrator
a number of things to consider here, but the short answer is to check the door switch.
Second is, if the dealer did the work take it back for warranty.
1 - 2 of 2 Posts
