Hi everyone. Long time reader here. I've been browsing this forum for over a decade. I am very thankful to have had access to the vast wealth of knowledege this forum provides. Its absolutely impressive. Typically I dont have to post anything. Whatever issue I come across on any of my trucks usually has pages of threads concerning the same issue and how to deal with it. This time it seems I'm not so lucky. There is posts describing the same issue I'm having now but they're old, dead and unresolved. So now I don't know what to do. I'm at the end of my rope with this truck. I don't have much hair left. I have a 2002 F350 Extended Cab Dually 4x4 with the infamously indestructable 7.3L Powerstroke . it's got 131k on the clock .Truck has aftermarket exhaust and cold air intake from the previous owner. I had a PHP hydra chip on it but have since removed it to rule it out as part of my issue. My issue is that the engine randomly just shuts off from time to time. It happens when I parked at idle and/or when I'm running 80mph down the highway. Sometimes it'll come right back to life and take back off. Other times it'll crank and crank but not fire off. It's as if the key gets turned off and back on again. Possibly the ignition switch itself shorting out???When it dies, I can hear the relays clicking under the dash and the glow pug light(WTS),water in fuel light and the engine light come on. And check gauges. just like it does when you first turn on the key. Also .when it dies, it seems I can revive it by pumping the go peddle. It seems like after the APPS resets its ok until what ever causes it to die happens again. Something else I noticed is, if I mash the go pedal to the floor it doesn't do anything and the engine light comes on until I get off the pedal. If I push on the pedal normally the engine responds as it should. But if I mash straight to the floor, the engine light comes on until I let off it and the rpm's never change.
Here's what I've already wasted time and money on and didn't help at all:
-CPS (3x's, last 2 were Motorcraft from local dealership) and pigtail.
-ICP (2x's, both Motorcraft from dealership) and pigtail
-IPR solenoid.( i bought the whole valve but only changed the solenoid so far. I don't think the valve is my issue) and pigtail.
-2 new batteries
- removed PhP Hydra chip
-new IDM
-Cleaned and inspected the battery + connection going through the firewall to fuse panel under the steering wheel on the driver's side fenderwell.
- taken the dash apart and the driverside inner fenderwell out to unplug an replug every connection and do wiggle wire test.
- unplugged aftermarket brake controller (didn't work anyway)
- oil level is good 1500+ miles until due for oil change
Here's a list of codes I pulled with ForScan U1058, U1059,U1027, U1262, B2658, B1352, B1318, P0123, P0603, and P0284.
When I do the KOEO injector buzz test, sometimes I get no buzzes at all and the P0123 comes up. Other times, it will buzz just fine on all 8 and say test completed successfully. no errors. So what do I do with that?
I took a couple videos of the truck acting up but can't figure out how to post them.
I hope somebody can steer me in the right direction. Otherwise the only thing I can think of to do next is to change the ignition switch and the accelerator pedal assembly. If that doesn't work,.. somebody needs to come get this thing before it catches on fire!
TIA
