1 - 1 of 1 Posts
This isn't a question, just a neat solution.
I thought I had a bad tie rod, the steering wheel seemed to have too much play, and the (automatic) shifter handle had too much movement.
Turns out (when I removed the fuse dash cover) that there is 2 torqs screws holding end of the shifter handle to the steering column. Well these were loose. Hard to get at without a torqs bit and a 1/4" box end to tighten.
When I cranked them tight, steering wheel play went away, and my shifter is tight.
Go figure.....
2003 ford F-350 lariat 7.3 4x4 crewcab long box.
1 - 1 of 1 Posts
