A dana 80 is 450ft#'s the sterling 10.5 I'm not sure. what ever it is you also need to adjust it according to the preload on the bearings, and the 10.5 I believe uses a crush sleeve instead of a thrust washer. so you need to get back to were it was or barely a little tighter, those are made to only be used once really.
