Need to know the pinion angle for a '01 f350.
not positive as the angle but why do you need to know? if your having vibrations with 6 inches of lift its probly your carrier bearing. you will need to replace it and shim the carrier bearing down usualy a quarter of an inch per inch of lift so 6 inches would need the carier bearing to be lowered about 1.5 inches.
hope that helps... if not ill go back to my corner and shut up :D
Not having any problems w/my truck. Asking question for a friends truck.
