Tell me what you guys think. Pulls air from the stock fender location as well as from behind the grill. It is mounted in place at the stock mounting locations. I used 1/8" vent line that I sliced to the top edge, the side edge that meets the inner fender and around each of the pipes. Mainly to keep from cutting myself working in the engine bay, but I didn't plan on the vent tubing actually quieting the intake noise down in the cab, but it did. I'm planning on wrapping the tubes with muffler wrap and also wrapping the box with heat mat, because I can. I figured it couldn't hurt. Inside of the box and any other exposed areas will be wrinkle black painted. Stock IAT sensor has been installed in the new air box. I'm thinking I might put the stock filter restriction gauge in the 4" pipe, again because I can.
