Hi All. Our 2003 6.0 with 239k. Went in recently for a p0278 and an intermittent very slight rough idle. Highly skilled Master Tech used IDS to diag and determine that injectors 2 and 6 were on their way out. Replaced 2/4/6/8 injectors and ICP sensor/harness as it was leaking around the harness. Also, blue spring kit and fresh fuel filters.
All was well for 700 miles or so before two injectors on the other side started to over-fuel. P0278 triggered again. The shop owner replaced the other bank of injectors at cost, no charge for labor even though it wasn’t his fault. A stand-up thing to do in my opinion.
Driving around today and sure enough, p0278 comes back with a very slight rough idle at stoplights. Pull over, cycle key, shift to drive and slight rough idle is gone.
I’m going to be humble here and ask for a reminder of the basics. There is no blow by, no tick or rapping sound, no smoke, no signs of a mechanical failure like a rocker or lifter. No loss of power at all. Perfect FICM voltage and ICP readings. The intermittent rough idle is so very slight when it happens but I can tell its there. No loss of oil or coolant and got 21mpg on I-85 today for 14 miles with the AC on full blast.
Point me away from overthinking and toward the basics I might be overlooking. Shop owner will absolutely make it right, I’m not at all worried. Just want some opinions on what might be the issue. I’m resisting hooking up to Forscan and trying to be a mechanic for just a bit.
