1 - 5 of 5 Posts
I just ordered a .84 AR turbo housing and was wondering if anyone has run this setup yet.
Yea I would have gone with the 1.00. If you pump up to stage 1s your going to have to change the housing again...
BIG TRUCK, SMALL DRIVER
I have ran a 1.0 and it worked great with stock injectors. I don't know anyone that has ran the .84. It should spool pretty quick, just make sure you have a pyro if you have a chip or tuner.
I plan on running this setup for now until I can get the stage 2s then I plan to and the D66 to the mix.
1 - 5 of 5 Posts
