My #8 perdel is high and #8 fails a CCT test.
Everything seems to be ok. It's my first time messing with forscan.
I know #8 failing is common but is that high perdel also the infamous #8.
#4 perdel is between 1 and 1.5, the rest are under 1 with #8 being between 4&4.5.
I'm guessing that I'm fine but thought I'd ask.
You've seen this? It's an interesting insight into perdel changes between cylinders with various CPS sensors...
No. I hadn't seen that. Very interesting and it seems that I'm fine. I'm going to see if I can see which CPS I have. The black is long gone so I think I can tell if it's gray or blue.
Interesting on that, I had a 95 and it ran funny on the blue but fine on the gray. I've got a spare blue in the glovebox of my 2001.
