1 - 5 of 5 Posts
I apologize in advance for the newbe question.
Where can I find out what my PCM code is? Trying to order a chip from Total Diesel.
Thank you.
wants to go 2wd to 4wd
Youve got to take the pcm out its easier than trying to do the butter knife thing.
I assume its listed on the outside of the PCM on the case/box?
Is the easiest way to remove it by the PHP write up?
Unbolt under the hood and remove the front driverside inner fender well? Or does it need to be removed from inside the truck?
Yeah remove it the way They explain Ive an 02 I didnt read what year your truck is but yeah remove it the way they said on the php site.
1 - 5 of 5 Posts
