1 - 13 of 13 Posts
Hi,
I'm new to the forum. I have a F150 lifted truck I built myself. My boyfriend has the 2001 F250 7.3 powerstroke. I know NOTHING about diesels so I need some help.
He purchased a SCT programmer Saturday. The guy told him it would correct tire size which it doesn't. According to SCT the tire/speedo/gears are NOT controlled by the PCM but by the speed control box.
His stock tire was 265/75R/16's. He's only running a 315/70R/17 tire.
Is the tire difference a big deal? Was the SCT guy correct on the PCM?
As far as I know it has not been regeared. I think the stock gears are 3.73's.
Any advice?
Thanks,
Christine
You can have the dealer retune the GEM module to tires up to 35's (315's). They will charge about one hour of shop time to do this...
John Wood Nut Swinger
We stayed with the SCT programmer because no programmer will change the tire/gear set up. That is run by the GEM where the programmer only affects the PCM. I think we've got 3.73 gears. I don't know if it's worth it, or needed to regear to 4.10. What's your opinion on that? Thanks.
Not worth it IMHO... I am running 37's with 3.73's and no issues.
it easy to recalibrate the speedo,took me about 2 minutes,the spped change could prolly get up to 8 or 9mph at higher speeds.
Discussion Starter · #7 ·
I'm not so worried about the speedo. It's running about 4 mph faster at 65 mph. I'm trying to eek every mpg I can since diesel in SoCal is $5.40 a gallon. I was wondering about gears on mpg and tranny wear.
Is the speedo recalibration a DIY project?
Yes, If you are a ford tech and have access to the dinosaur of a tool required. Maybe you know somebody that works at a dealer? A friend is how I got mine recalibrated.
no need to regear until 38"+ tires. tranny is gonna push his tires easily. You won't get an accurate mpg reading with a speedo that is off, so you cant really calculate that until the speedo is fixed, or you use a gps of some sort. There are I think 4 options for getting the speedo where it should be. All are around $200 excluding the Ford option, which ranges from $50-$100 depending on who you go to.
1. Ford - can only do up to 35" tires
2. Truspeed by Superlift - TruSpeed™ Speed Sensor Recalibrator · Superlift · www.superlift.com
3. Respeed by TS performance - http://tsperformance.com/respeed.html
4. Speed Wizard by Merlin - Speed Wizard Speedometer Correction
have Jody at DP tuner get some tunes for ya for that SCT. your b/f will be on cloud 9 until he gets used to the power. Theres also a nice economy tune he can get for ya.
yes, its easy in a 97, but not a 2001
thanks sirn, if anybody has questions on the speed wizard just email me [email protected]
I am here to help people - i try to visit all these sites and help people with questions on speedsignal but theres 1 of me and many of you all
kenny
1 - 13 of 13 Posts
