1 - 5 of 5 Posts
I'm in a little bind and looking fir some parts. I'm in to a rebuild and broke some rocker arm retaining clips. I'm looking for some in the Austin, Houston or San Antonio Area. I've got the cab off and loose use of my crane tomorrow to reset the cab so I need something tomorrow. TIA!!
Sent from my Pixel 4 using Tapatalk
I just found a guy in Round Rock that seems to have a good salvage stock of PSD. Probably shouldn't post his name here, but if you search "Partes de trucas" you might find him.
Unless I am missing something - the part is only $4.
Yep, you're correct. All the Stealerships were out. I ended up ordering some from Amazon and waiting an extra couple of days in them. I ended up putting the passenger side back together with the good rocker box and putting the cab back on. Once the clips came in I put the driver side back together.
1 - 5 of 5 Posts
