1 - 7 of 7 Posts
Ive got a almost complete 2003 6.0 motor im parting, its currently in peices. Motor has 153k on it. Some surface rust on some parts but nothing major. #8 piston damage. I do not know at this time if the cylinder is Scored. Going to clean up everything when i have the time. DO NOT have turbo or ficm at this time. Not too sure on prices yet, just putting this out here. Will have pictures upon request. Everything located in charleston,West Virginia. My cell which you can reach me at anytime is 304-550-4254.
Some thing off the top of my head,(have lots more)-
3 injectors
2 oil coolers(1 has 153k,1 has less than 5k miles on it)
Intake manifold
Heads(both should be fine,Going to investigate tommorow)
2005 HPOP (less than 10k)
2003 turbo pedistal
water pump
front cover
Exhaust manifolds
oil rails
block if good will find out tommorow for sure 8/21/11
Have more will, update tommorow. Text or call for quicker response.
Discussion Starter #2
-Block looks good, just needs piston.
-Driver side head on #8 needs intake valves, and head machined
-passenger side head looks good
-Ipr sensor,and a whole bunch of misc stuff in last pics.
Pictures on snapfish.
Snapfish: Log In
bump.......
Bump. Also have front cover,harmonic balancer, block is good just needs cleaned.
bump!!!!!!!
1 - 7 of 7 Posts
