1 - 8 of 8 Posts
Parting out 1998 E350 with a 7.3 Powerstroke engine and automatic 2wd tranny. Runs and drives good but body is bad and damaged. No front damage, only on the left side. Doors good. Odometer has 203K. Injectors changed at 112K. (AB"s). Complete engine $1,950. Will not separate!! Engine includes all basic items; turbo, injectors, exhaust manifolds, HPOP, water pump, oil cooler, motor mounts. Tranny 2wd $650. Radiator $100. Clutch fan $75. Located in Pa.
if you will sell just the injectors pm me
is the engine still around
Are you selling the rear axle?
Just a few questions about that rear axle....
Is that the one with disc brakes? Also, did it have the OBS bolt pattern?
If yes to both above, what is the gear ratio?
Thanks!:thumb:
1 - 8 of 8 Posts
