Does anyone know the part number for the updated Turbo oil feed line? I also need the new turbo gasket set which should be easy to get, and also i need new gasket set to install a new intake. Is there another gasket set that im missing or should update while i have the top half of the motor tore off?
Updated turbo feed line: 3C3Z-9T516-A International 1845287C95
Updated turbo drain tube: 6C3Z-9T515-A International 1876071C91
Turbo hardware kit: 3C3Z-9T514-AD
thanks bud. Im debating if i should do an oil cooler, i have been seeing alot of people say do it, is the factory one not a good one or is there not a factory one at all?
do a factory rebuild..you are better off to do it and not need it then not do it a need it in a month,week or day...
