1 - 20 of 24 Posts
well i did a search and didnt really find much, i read on another forum how to mod the headlight switch mechanism so that you can have your fog lights on without the headlights having to be on, but it didnt work.:dunno: my fog light switch pulls out with the parking lights on, however the fogs wont turn on unless the headlights are on.. does anyone know the way to do this? i seen trucks driving around with just the fogs on, i really wouldnt want to add an extra switch just for the fog lights, im sure theres a trick somewhere, any help is appreciated.. thanks in advance!
International Threat
On the 02's and up its jumping a wire... on the 01's... you need to add another switch.
I have a 02. I would like to just be able to turn my fogs on. Any idea what wire to jump?
Anyone have a write up for an 02?
I saw one driving with just the fogs on and it looked sweet!
I think it's a wire you jump under the hood... I could be wrong though.
It's called the steve something mod IIRC...
heres a bump. sounds cool. on a 02, how do you turn on the fogs? do you just make the switch so it pulls out in a different place also?
Its the Steveracer mod Marty
anyone know of a right up anywhere?
thank you!
I have a canadian truck. But my day time running lights have been turned off. Will this mod work?
This is super easy to do...he spells it out well. This is one of the first mods and still one of my favorite mods I have done to my truck. Of course I did it for a different reason, I wanted the fogs on when the highbeams are too. Country roads out here can get dark as he!!
later
OK with mod how do you trun your fog lights on by the swith or are they alway on with key Brain is not working to good today. and if you do trun them on with the switch how mine will not come on unless headlight are on:dunno:
I some how managed to get my fog lights to work with the parking lights when I Installed My remote starter, I broke one of the mounting tabs on the light switch, cant tell it mounted up the same, but I can turn the fog lights on with the parking lights:dunno:
I also did this mod, but am not able to run the foglights with the parking lights. For my foglights to turn on, I need the headlights on, or I can't pull the switch out. Did I skip a step in this mod?
You mean your switch won't even pill out in the parking light position? It should.
Nope, my switch has never pulled out unless it was in the headlight poition, and actually is pulled back in when taken out of headlight position.
huh, that's the way mine is from parking light to off position. not from headlight to parking light position like yours is. You have an 03 6.0, thinks that makes a difference?? IDK Maybe thats something they changed. :shrug:
I didn't have to modify my switch itself, it always operated this way but the lights just didn't come on...
1 - 20 of 24 Posts
