1 - 5 of 5 Posts
· Registered
Hi all,
Ford e-450 2003 7.3l
I have change my brake pad on my parking brake monted on my transmission. I have change the brake pad, speedo gear, and the seal on transmission side. When i put it all togheter without tihtning the main bolt i can turn by hand the drum, but when i thingten the bolt at 215 ftlb i can't turn it by and anymore. I have not put oil in it before trying to turn by hand.
I have not change the bearing because it was good shape and i dont want to change the shim.
I follow this step in link bellow
Can it be turned by hand after the brake was rebult ?
thank you
· Registered
We have annual inspection for big truck here, the parking was not working. I have look for a new assembly, but was 3700$ CAD at stealership. I order new part on ebay to rebuilt it. When i remove the assembly i see some oil leak on transmission side, so i change this seal to, with brake pad. I will take more picture next time when a disassembled something :)
1 - 5 of 5 Posts
