1 - 7 of 7 Posts
Hi, My dads truck pulled the code 1280 and all I can remember the scanner saying was "Fuel/Air Metering". He has a 2003 7.3L and the only mods are a Hypertech and a Magnaflow exhaust. Any help would be great!. thanks.
Could a biased ICP sensor, or shorted ICP. look at scan data, see if desired and actual close.
I just used my generic $100 mac scanner and all it really does is give you a code and a short discription, so I don't have any scan data available.
But I will look into the ICP (Injection Control Pressure sensor, right?) but I would rather not replace it if its not bad seeing as its about $170. Any ides how to know what it id for sure? Need to hook it to a better scanner i bet.
Thanks!
WHere is the ICP sensor located? THanks!
1 - 7 of 7 Posts
