1 - 10 of 10 Posts
Addicted to Diesel
got the p0743 code today.... i was searching around and everyone else who had this also got a p0741 code. maybe my scanner didnt pull that one :dunno:?
What to do now. f81z-7g391-cb is the part number needed right? is this just something i am going to have to go into ford for?
Addicted to Diesel
with this code the truck has been really rough. stumbling, a lot of change in the rpms. wont idle properly. but it does this intermittently, it is not everytime i drive or all the time whne driving. also the torque converter wont lock up.
so i know this code would cause the torque converter problems but are the other symptoms common to this or do i have another problem along with it?
Addicted to Diesel
ok thanks. that is what i am going to do. i am taking it back to the trans shop that just did the work on it, they said they would get it all figured out.
Addicted to Diesel
Discussion Starter · #8 ·
do you happen to know about the symtoms i have discribed above?
Addicted to Diesel
Discussion Starter · #10 ·
alright good to know. i will see what happens after the transmission shop is done and go from there.
1 - 10 of 10 Posts
