Hey guys need some insight here. Have a 2015 6.7 that just threw a P02D8 cel light out of the blue. I recently had the truck apart to repair an upper oil pan leak. Have probably put 150-200 Miles on it issue free since fixing the upper pan leak. I did notice before I left home after work the engine sounded louder than normal, but was running fine. I cleared the code and haven’t seen it back yet with probably 60miles since cleared.
Any relation to having the pan off with this cyl7 offset learning at min code? I haven’t found too much online about this.
Reset all fuel tables and adaptive high pressure tables and it’ll probably clear itself out.
