1 - 2 of 2 Posts
So I have a 2008 F350 I changed out the HPFP gasket harness that was shorted out, put everything back together and ran perfectly for one whole day. The turbo was not seated correctly and was leaking oil I fixed that and when I went to start it I get P0001 crank no start. I took it all back apart and inspected just in case but all is connected correctly. If I change the fuel rail pressure sensor would that fix the code? Any help would be appreciated.
769820
1 - 2 of 2 Posts
