1 - 2 of 2 Posts
I bought this truck last winter in WA.
We bought a 16' enclosed trailer and sort of converted it to a toy hauler/camper. Have a Sportster and a Can Am Spyder that we took along.
We drove from OR to the UP of MI via Boise and back. Over 5K miles.
I was a bit concerned about my oil/coolant temp deltas. I run about 11 degree difference when checking it according to the Ford spec sheet.
The truck ran without a hitch. Used no oil. Had to add a few cups of antifreeze, but that was low from a blue spring install(disconnected the top radiator hose at the radiator) and a coolant filter install.
My EOT maxed one time at around 248 and the coolant reached close to 230 one time. I took it easy over some of the hills..slowed down to 45 instead of pushing the speed limit. That seemed to help some.
Anyway, I m still on the fence with the cooling system flush/oil cooler change. I m not sure if it needs it yet. The coolant is really clean. The filter I took off had no dirt in it, at least nothing visible.
Anyway, we had a great time, truck ran flawlessly, Life is Good!!
Brad,back in OR.(and tired of driving his truck!)
Sounds like everything went well. That was a long trip.
Time to change the oil and give her a rest. A little more good weather for a few weeks, jump on your other ride, and go sight seeing a little closer to home!
And, by the way, you will miss driving it in a few days!
1 - 2 of 2 Posts
