1 - 11 of 11 Posts
Both my front tires are wearing down on the outside for some reason. I took it to NTB twice and the alignment is in spec. I'm not sure what else can be the problem. I'll double check the PSI later today but I can't imagine it doing that much damage. I just rotated the tires to see if it's still wearing down. I also made an appointment with Ford in two days to get it checked out. Anyone else had this problem?
28k miles on stock suspension and tires.
I have the same problem on my front tires, 2015 350 DRW. Had the dealer check the alignment and it's all good. I normally keep them inflated to about 70psi cold... I'll try a higher pressure.
1 - 11 of 11 Posts
