1 - 8 of 8 Posts
Not that I know anything else about it...but I noticed that O'Reilly's Global ATF gallon jugs had "suitable for Mercon SP/LV use" or something to that effect on the front label. Other fluids like ATF+4 Mopar and Dex VI were also listed.
Only problem was I can order genuine Motorcraft SP from O'Reillys cheaper per quart than what they are charging for their "Global ATF". I pointed that out to the store manager (as if he cares). I imagine the same would hold true for Mopar and GM fluids the Global also replaces. But I didn't check those prices.
What's special about SP anyway that makes it so unique? Whatever it is, O'Reilly seems to think it has a formula for it.
O'reilly's can order the SP for you and here in MI at a good price! Just ask them. I have been where you are and was told to NOT use the Global.
~Matt.
How many quarts does a drain and fill and inline filter change take?
I would not use ANY fluid but sp or lv! A few years back I used one that claimed the same thing. My truck shifted terrible. I did half flush 2 days later then another one in a week or so. The tranny went back to normal after that.
Sent from my DROID Pro using AutoGuide.Com Free App
WWW.COMPIGNTECH.COM
The transmission and torque converter and filters and cooler all hold around 20qts. What I did was drain the pain and drop it then swap the in pan filter. Reinstalled the pan and replaced the cartridge filter by the trans cooler. I then added 9qts of fluid and started the truck and let it run for about 5 mins so it would suck the new good fluid out of the pan and swap it with the fluid in the torque converter and lines. Then I drained and refilled again. Thats the best way to do it if you don't want to do a heated flush at the dealership for $300.
About 8 quarts. Mine took that much. I drained my tranny into containers so I could measure the amount, and it was close to 8.
:thankyou2:
Discussion Starter · #8 ·
I already ordered my Motorcraft SP a while ago from them. It's all I'd use, and besides it's cheaper per quart than their house brand. I was just pointing out it's one of the few I've seen which at least says it's SP/LV suitable. Whether it works well or not I don't know.
1 - 8 of 8 Posts
