1 - 7 of 7 Posts
just wondering if any one else has this issue? when dpf was on idle was fine then i put on delete and it went up
Are you talking about RPM's?
ya rpms, tried blurping throtle to get it to come back down and it stays up a little to high
What tuning is this?
I would bet he did not install the tune yet and it kicked into regen.
^^^ what he said..
You *did* re-tune it to disable the regen process, right? Your message didn't mention that part.
that would not be a good situation if that happened, then the DPF is basically pointless:doh:
1 - 7 of 7 Posts
