ok I have been seeing few really good King Racnhes 6.0 04-05 low miles for sale. But in the long run I need to swap the center console for a 3 seatbelt bench up front. Here goes
1. Can I just swap the console for the jumper middle seat?
2. does it seem possible to take off KRanch leather off of front seats and slip on bench seat?
worst case I get a cover for the jumper middle seat.
Thanks :wink[3]:
Well the answer is yes and no. If you get a once piece bench you will not be able to swap the seat covers for obvious reasons. If you swap for a 3 piece bench then yes the covers will swap but you will have a hole in the side where the arm rests were. Yes you can just swap your center console with a jump seat but you have to do some modifications to the capt chairs.
I swapped my center console for a jump seat but you have to remove the arm rests from the captain chairs and then pull the covers partially off of the capt chairs and removed the mounting bolts from the frame. I used a cutting wheel and removed the mounting bolts from the frame of the chair . It leaves a small hole in the side leather of your captain chair but the center console covers it up. You can swap all 3 seats out, but for me it was easier to do it that way then a complete swap. The whole project only took me about 2 hours to do. If you have any questions or need some pics just drop me a PM.
