1 - 2 of 2 Posts
Do you know if I could fit a cat back exhaust from a prior year SD to my 08 as a DPF back? I am sure I would have to shorten it up, but the bend over the axle and the outlet should be very similar.
I do not see where there are huge differences in the chassis dimensions of any SD truck.
Thanks for the help.
The overall dimensions are the same, but the stock hanger placement is different.
Just buy an MBRP filter back. You have a ton of options.
With the delete pipe you bought from me, you can just hook it up and go.
If you decide to go complete delete some day, all you need to do is to remove the 3 1/2" to 4" adapter and hook it up.
This is the one that I bought. It's also the cheapest price I found.
Aluminized is all you need, unless you like shiney things where you can't see them...
08+ Ford 6.4L Powerstroke F250/F350/F450 DPF Back MBRP Dual Aluminized Exhaust S
I added these for the hell of it, they look great.
Flo-Pro 4 Inch Inlet 6 Inch Outlet Stainless Clamp-On Exhaust Tip
1 - 2 of 2 Posts
