1 - 9 of 9 Posts
Took my hfcm off today for thorough cleaning and I have the 3 wire connectors, when I
776628
776629
776630
opened up module, little round disc fell out, I see where it goes, question is can I glue it back on, I'd rather try and repair it than switching to new hfcm and wiring harness, any help would be greatly appreciated.
that is the fuel heater that was omitted later on. i had the same question couple months ago
i was advised to not plug it in and pull the fuse for it, as i broke mine when i pulled my cover off.
Okay, thanks alot, so I can just not plug that one in to the harness and try to find the fuse for it under the dash.
Administrator
you can also get a new cover 6C3Z9B249A and updated harness 6C3Z-9F759-A
the updated drain plug is a nice add also 6E7Z-9C082-A ( edit I see u have it already it will work with the newer cover also )
Has anyone purchased the whole replacement hfcm off eBay, and updated wiring harness, looks like I can get one with aluminum cap for 188$, and 9bucks for a harness, save me a lot of duckies, just question if they're reliable or if anyone else has had success with them(aftermarket)?
Administrator
unless its a factory part I would pass.
this is a risk you would have to be comfortable with because it could leave you stranded when it fails.
1 - 9 of 9 Posts
