Well I had the batteries out yesterday when I installed Painted valve cover and snapped a few Pics of my dual passenger side pics. Alot of you have asked for pics and well here they are.
Picture of the bi-level battery tray. Sorry camera phone pics are not that good.
All hooked up and in place.
what did you have to do that
Custom made a bi-level batery tray that bolts to the inner fender well. The only thing is you have to ditch the vaccum boost tank or relocate to the frame rail. next you have to ditch the window wash tank or cut the neck of it off and modify it with a remote resiovor to fill it with. Slide obe battery under the front crossmember then the other one right behind it then re-use the batter holddown clamp to hold them in place. Have to modify batery cable to make look decent or just make it work, i just recently cut them and soldered new ends on them. It was alot of work but freed up alot of space on driver side for air filter. Im going to build a custom airbox eventually.
