Hi Guys,
How hot does the oil temp get when pulling a heavy load. I have an 04 6.0.
I was seeing an oil temp of 260 when the outside temp was 106.
I was seeing about the same when i was unloaded on the interstate. the outside temp was 75 and my coolant temp was 190.. don't know if it is good or bad i am baout the post the question the general area.
It sounds high you might have a plugged oil cooler you coolant and oil temp should not be more than 20 degrees deference.
