The plug is the problem. They have updated seals for the plugs ( known as D-rings). There is a plug for each rail and on each plug there are two seals. The part #'s are
W301390
w301386
I see you have an 06 so you should replace the stc fitting with the upgraded fitting if you are going to be in that neck of the woods.
Thanks for the help.
Yes I will do that and other updates when I do studs like the turbo ol drain pipe, full egr delete, and other stuff I cant think of right now.
