1 - 5 of 5 Posts
haters gonna hate 24/7.
I was driving to work this morning and i noticed my oil pressure gauge was pegged at H. I stopped and turned the truck off and restarted the truck and it was still pegged at H. Then right before i got to work, the gauge went back to reading normal.... Anybody else have this problem???
I appreciate the help ya'll
sounds like your gauge may be giving you a false read if its spiratic like that? Anyone else got an idea?
Nuckin' Futz
id find out if your oil pump was acting up and the pressure relief got stuck closed for a bit there...id do that promptly before you blow out all your seals if it is that...then if it isn't you can look at your gauge as being the problem.
Does you fuel guage do that too? mine has a mind of its own, and ive heard its common.....
Well the fuel one is casued by dirt in the senser when you only fill one tank...there different problems
1 - 5 of 5 Posts
