1 - 5 of 5 Posts
ok so not only is there a slow leak in my oil pan but someone else already tryed to repair it by putting some fiberglass/epoxy crap on there and i dont want to take that off because im afraid that if i do there may be a big rusted out hole in my pan which would be even harder to repair so my question is how can i repair the leaks now?
Welcome to the ORG.
If I were you I would want to know what was behind that patch. The best way to fix the leak unfortunately is to pull the pan!
but pulling the pan requires pulling the engine doesnt it .... god i hope theres an easier way
I would like to know as well because mine is doing the same thing. Not leaking bad but previous owner put some kind of crap on the pan. It's just leaking a bit now but of course will get worse.
yes unfortunately you have to pull the whole engine out because it was a bad design. unless you could find a way to remove the crossmember. if it was me i would just do it right the first time instead of having to fool with it for a long time. replace the pan.
1 - 5 of 5 Posts
