Ok so I bought an 05 6.0 CCLB and pop the hood to change the filter cap from the tall one to the OEM. Well since I have done this I have developed an oil leak and I have no idea where it is coming from. At first I thought it my turbo feed tube but that was false. The oil is collecting in my valley and drops all over my driveway when Parked as it has a slope. Would my oil filter housing be doing this or what. I have no issues with Delta's or oil pressure.
I was dumping oil from my turbo return, it did this, but I'd think you blew the oring under the filter canister. Can you get in there with a flashlight and see if there's oil around the base of the filter housing?
It looks as if that is the case. There is oil around that general area.
