1 - 16 of 16 Posts
Ive got oil drippin out of my 6.0. I am pretty sure its not the main seal cause there is oil on the block above the tranny. Is it the intake gasket or are there other possibilities?:dunno:
that makes me feel better cause that would be a pain in th:bottom:
Number 7 glow plug connector can leak down to the bellhousing along with a leaking camshaft position sensor, the bedplate can also leak due to maching defects, these are just a few things to look at
What year is your truck? If it is an '03 and the oil is comming down from the top of the block more towards the drivers side of the bellhousing, it will almost certainly be the ICP sensor. It could also be as WEWILLE stated. "Usually" if its leaking from the rear main the oil will drop straight down the center of the bellhousing, by the inspection hole.
<-Day Of Fail now SOLD
Had the same problem turns out needed new cam sensor and glowplug harness.
Had the same problem turns out needed new cam sensor and glowplug harness with gromit kit.
Discussion Starter · #9 ·
I havent located it yet due to lack of time but I can tell you that its about1/4 of a quart that leaks out during a 15 minute drive. It is all the way to the back of my exhaust its leakin so bad. Thanks for the help i am about to go check it out now.
what is the year of the truck?
Discussion Starter · #11 ·
It is the early 2003
if its leaking that bad , it more than likely the icp sensor on the back of the engine , the arre bad for that
sounds like we have the same problem . were is the camshaft positioning sensor located?
Front left side of motor just above bed plate. Cam sensor o-rings typically don't leak alot of oil. So, if it's dripping or there is alot of oil at the back of the engine it's probably the icp sensor. If you remove the heat shield at the back of the engine above the trans bellhousing (3 bolts) and slide the silver protective cover back from the icp connector you can see if it's leaking from the icp sensor.
1 - 16 of 16 Posts
