1 - 7 of 7 Posts
It looks like I have a small oil leak about the size of two quaters in about 1.5 days. It looks like it is coming from right above the exhaust manifolds their is a black hose that looks corragated and it goes into the engine! When I put my finger on them they feel loose and I don't want to mess with them untill I know what they are and how they go in. It looks like it is one on each side and then it runs to the back of the block then down and drips off the trans pan!! Please help!
Thanks,
Rich
Discussion Starter #2
Sorry I did not mean trans pan I meant bell housing.
I will try to post some pics tomorrow if no one has any ideas
My rocker box had a small porous area! Ford said sol because im not the original owner! To fix it it is just like doing heads, and replace the rocker box.
Firefighter Member
It is the ICP sensor on the back of the engine block in the vally. The middle of the sensor breaks and it comes out there. This is a common thing from what I was told. Fun to replace. Real time consuming.
my icp sensor is on pass side valve cover.
1 - 7 of 7 Posts
