1 - 20 of 22 Posts
I was goin to change my oil but i thought about goin from rotella 15-40 to delvac 10w-30. Any pointers or comments please.. thanks
War is the answer!
Why 10w30?
Sent from my SPH-L710 using AutoGuide.Com Free App
oil
I second the choice for Amsoil, either the 5-30 Series 3000 or their 15-40 Marine oil. I have been using their products for over 20 years and have never been let down. Their products always work better than advertised.
Frank
:icon_ford
You want 40 weight oil in your 6.0 and most diesels. 5w40 helps on cold starts because it is a 5 weight when cold and 40 weight when warm. You have to be in extreme cold before you drop to a 30 weight oil, -30* and colder.
T6 rotella 5-40 is the best choice for 6.0 liter.
I have the BPD oil cooler and relocated oil filter. Is the T6 rotella 5-40 still recommended? I also have the Napa Gold oil filter 1832. Thx!,
Sent from my iPad using Autoguide
I cant imagine an oil cooler changing a requirement of viscosity. Rotella T6 is the most cost effective synthetic out there. $21/gallon at Wally World.
I've been using 10w-30 for a few years with excellent UOA results.
For as long as I own a 6.0 its the only viscosity lube I'll use.
I hate changing the end weight of oil. Tolerances are specific to motors and oil compliments how that motor is built. 5/40 is tested and tried. And ya got to run racor or ford filters - bottom line. There is proof of that all over the place.
I would run a 30w oil if I was one of the northern friends or on an iceberg
I have always used Motorcraft 15w-40 powerstroke oil. Easy 5 quart jugs and is cheap at Walmart. Works good for me.
Drink the coolaid man!!! Many improvements in diesel oil since our manuals were written. switch the the 5 synthetic, the old lady will wake up better in the am!
Easy 4 quart jugs at walmart for $20! 3 and 3 qurts!
correct me if im wrong but i have heard the motorcraft oil filters are only required if you still run the stock set up... The truck currently has a Baldwin B5134 on it with the BPD oil cooler kit. Thx again for the help. :icon_ford:
Yes, talking about stock setup.
100% correct!!!! Didnt see you had cooler kit.
Oops my last post I mentioned the Baldwin filter, thats the one on my coolant system. The current oil filter on my truck is a Carquest 85832 but found the Napa 1832 as a cross reference. Thx again for the tips, I'm gonna fill her up with some T6 Rotella!!
Make sure you use motorcraft filter.
Recently went to Delo 400 5w40...I'm certain I'm getting 1+mpg gain off the switch. Just went 470+ miles leaving 1/4 left on a 38gal tank. I'm not sold it's a true 1+ but I'm not even filling up to the cap and getting these numbers.
Synthetics work for me with 217k on the original injectors. I'm a user!!
1 - 20 of 22 Posts
