Is there any way to route a cooling line to the oil cooler and a line to the EGR cooler, and keep them separate? All while keeping proper function of both. With the general idea to eliminate the chain of events problem oil cooler clog, egr cooler rupture, heads lift. I'm just curious because if you ran them on 2 separate cooling lines from the degas bottle then the oil cooler couldn't deprive the EGR of coolant and it wouldn't flash boil. I would just like to know if this is a feasible idea.
