1 - 9 of 9 Posts
I have an '03 F250 7.3 PSD. My question is. I only put on 4,000 miles in a year maybe. Retired, live in Wisconsin. oil change for summer and winter. can I run 5W40 Rotella syn. all year around?? 17 quarts each change, 2 times a year is ALOT of money!!!!! :dunno:
If the rotella syn is something like Amsoil or Schafers, they say you can run over a year on an oil change (with proper filtering)...
but if I were you, I'd just do an oil analysis to check it out and see what your needs are from there...
i dont think a 5w-40 would hurt anything in the summer. I thought amsoil said 1year in nonturbo diesels and 6months in turbo diesels?
You could be right -- I'm just going by what I've seen on all sorts of forums..
I think most people taht are going to try to do extended intervals do Oil Analysis anyway.... just to be safe
Your truck should only take 15 quarts, not 17...
oil change
'03 7.3 PSD. Late last fall changed my oil, no new filter, put in 16 quarts truck on level ground. the dip stick was about ¼" from the top of the shaded area. So with a new oil filter it should take around 17 quarts.I don't have a service manual. Any techs know for sure?
I worked as a lube tech for close to 2 years...
No hard feelings:hehe: But 12 with no filter sounds about right.
1 - 9 of 9 Posts
