1 - 12 of 12 Posts
hey there, new guy again, I recently bought a 2004 f250sd with a 6.0l. The trucks owners manual says I need sh or si oil. I just changed the oil and used sj-4, rotella t. is this ok. oh, it was 15w45. thanks
The sh and si oil are intended for pre 08 powerstroke engines. You can use the sj-4 oil but the oil change interval is cut in half. Needs to be changed at 2500 miles instead of 5000 miles. Has something to do with the new ulsd fuel. Hope this helps some, and if I'm not 100% correct, I'm sure someone will let me know :nod:.
On my 97 I`m using Rotella 15w40 but I am planning on changing to Amsoil or Castrol synthetic. (more protection and actually cheaper if you factor in the oil change intervals).
i have been running royal purple, its a little pricey but what a differance it makes. what is the best chip system for the 05 6.0 turbo diesel?
Use amsoil, and double the service interval to 10k. They say it will go 25k, but apparently the way I drive it doesn't last that long. You should also notice a little mileage increase when switching over.
I put amsoil in everything that holds fluid. When I switched my lawnmower over to amsoil, my grass became much greener, and I haven't had any clover or ant problems since. I believe Amsoil is the answer to world peace.
I heard Amsoil is the SH*T, just change ur filter and go
I wouldn't go that far. The "Change the filter and Go" system only works with frequent oil analysis, which costs about $26 every 15k.
:hehe::hehe::hehe: That is to funny...
I've been happy with my 5-40 Rotella Syn. So far I have about 4k on it and it's still in good shape, MPG's haven't dropped and it's not nasty looking. That's my free oil anaylysis. Look, feel and MPG's. But I can't see myself running it longer than 6-7k.
I found a PDF with the results of something like 600 oil analysis samples. Seems like you might be interested in that sort of thing, so let me know and I'd be glad to send it to ya
I have been runing Rotella 15-40 and the ford manual says change every 7500mi so that is what I do... So what are the oils that seem to give you better millage? and longer service intervals?
A good synthetic oil and a good filter is very important. Amsoil syn, Castrol syn, Mobile 1 syn. come to mind. Motocraft filter FL1995 and the Amsoil filter (I like this one) are good choices. Recommended change is 25000 mi. but I think 15000 or so is better depending on towing, getting on it etc. Diesels run better with new oil in it. One guy I know gets 25000 on his oil and sends a sample in and if it tests good he changes the filter only but I don`t recommend that. You will get much better protection for your engine and if you balance the cost per change it is actually cheaper than regular oils.
1 - 12 of 12 Posts
