1 - 8 of 8 Posts
was just wondering if there is anyway to get the oil out of the high pressure pump resivor when changing oil with out taking oil cooler out???
Administrator
no one worries about it that on a 6.0 like some other engines
at least I have never read one thread about it
Bill Hewitt at Powerstrokehelp will change it for you. :hehe:
Why worry about it? The amount of oil left after drain is so little that will not affect the new oil.
WWW.COMPIGNTECH.COM
The amount left in after an oil drain is around 3-4 quarts. 18 qts total capacity.
Are you sure Mark? The HPO reservoir only holds about 1 to 1 1/2 quarts and I know mine only takes 15 quarts on regular oil changes and when I did studs and gaskets I drained the reservoir out and oil rails obviously and when I refilled it took exactly 4 gallons to reach full on the dipstick.
War is the answer!
18qt dry is correct. But unless you have serious oil issues you don't need to worry about the oil in the HPOP.
Sent from my SPH-L710 using AutoGuide.Com Free App
1 - 8 of 8 Posts
