Hey everyone, I know I've been making a lot of topics recently! But I am changing my injectors to stage ones, as most of you may know. I also need an oil change, should I change my oil before installing the injectors or should I change it after? Does it matter? Thank you
After. After the fuel and oil from the rails drain into the cylinders, it can make it's way into the crankcase (depending on the method you use to get rid of the drained fuel/oil). Changing it after would at least get rid of any fuel that may have gotten in the CC. Cheers!
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Ford Powerstroke Diesel Forum
