1 - 7 of 7 Posts
Four oil changes so far on our year old '07 6.0, in an E450, rv-about 12,000 miles. First change was not tested, the original factory fill, second change, tested, was Ford 15-40 dino, second change, tested was Amsoil 15-40 synthetic, third change, tested, was Del 1.
Across the board the wear metals are very close, the lab language is, "similar wear characteristics, very low wear levels".
Its -beginning- to look like it doesn't make a hoot what juice you use so long as you change often; I think................
Oh yeah,
no glycol !!!!!!!!!!!!!!!!!!!!!!!:woot:
I kind of agree. Granted they are not all the same, but I put more stock in the filter and changing it when needed and running the approved CJ-4 oil.
I have to agree -- as long as you're using a good quality oil and changing frequently, you shouldn't have anything but great results on the oil analysis. I've run mostly Rotella-T synthetic but switched to AmSoil about 25k miles ago. I'm confident that I can run the AmSoil for 8k miles with a filter change at 4k and still be very, very well protected. I'm not confident that I could do that with the Rotella and I was changing the oil and filters every 5k miles.
--Snake
--Snake
Dino Rotella, change it every 8k, oil analysis every other change.
All metals well within parameters, Blackstone always says I could have ran the oil another 2k.
:dunno:
I run RotellaT synthetic. The truck always starts complaining at about 5k. The idle is louder, and the mileage drops over 20% by 6k. A friend of mine has an 06 Powerstroke too, and his exhibits the same behavior. I used to run RotellaT dino, and it seemed to last the same 5k or so, but I get 1-2 MPG better on the synthetic, so that's all I run now.
Mine starts complaining at 5k also. Mileage drop is the biggest sign it's time for a OC. I just tried the new 15-40 CJ4 rotella this time around and so far I'm very happy. Good price to boot. That's the main reason I don't run Synthetic oil, it's not CJ4 and it's expensive.
Both Delvac 1 (also Mobil 1 Turbo Diesel Truck, exact same stuff, this according to Mobil themselves) and Amsoil 14-40 Heavy Duty Diesel and Marine) EXCEED CJ4 and CI 4 plus.
1 - 7 of 7 Posts
