1 - 5 of 5 Posts
So there is a 2001 f250 cc/sb 4x4 7.3 for sale i am looking at for sale at a used car dealer. It has 109k miles new tires and is priced at $14,900. I got an Oasis report... What do you think? Seems like more problems than most of you 7.3 owners have had...
OASIS RESULT:
1FTNW21F91EC30630
05/20/2008
18:55:50
FCXWS447
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
// for our friends in vrep var strVehDesc = "2001 F-SERIES"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 F-SERIES< td> BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
1F719S0A WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE ARN MESSAGES GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/17/2001 BUILD DATE
02/26/2001 SALE MILEAGE
OUTSTANDING FIELD SERVICE ACTIONS
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 10 7S22 180106 F2UZ 14526 M P01 46 31821 AWS Claim Key: 6248264 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: B8122 - * Name: EASTWAY FORD SALES LTD Ph: 519-6315080 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:14-JAN-2002 Doc #:10292801 Cust Comments: INSPECT FOR VEH NOT MOVING IN EITHER REVERSE OR DRIVE WHEN PUT INTOGEAR Tech Comments: VERIFY CONCERN, NGS TEST, PID DATA TEST, PINPOINT TEST, REPLACED EVTM0 AMP FUSE, RETEST 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 10 7S22 180106 F2UZ 14526 P D50 28 34488 AWS Claim Key: 6858210 Trx Code: E83 Labor Hrs: 4.4
Dlr Cd-Sub Cd: A8303 - * Name: TALBOT FORD LINCOLN SALES LIMITED Ph: 519-6315800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:06-FEB-2002 Doc #:11007201 Cust Comments: VEH HAS LOST POWER WOULD NOT GO OVER 20 KM/HR Tech Comments: DIAG, REPLACE FUES AND PIN TEST WIRING REPAIR 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 10 5K01 040401 * 1007 * N12 13 34488 AWS Claim Key: 7097463 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: A8303 - * Name: TALBOT FORD LINCOLN SALES LIMITED Ph: 519-6315800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:06-FEB-2002 Doc #:11007202 Cust Comments: NOISE FROM FRT END POSS BEARING NOISE Tech Comments: DIAG, CK RUN OUT ON TIRES 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 10 * * * * * * * 34488 AWS Claim Key: 6858211 Trx Code: 01S21 Labor Hrs: 0.3
Dlr Cd-Sub Cd: A8303 - * Name: TALBOT FORD LINCOLN SALES LIMITED Ph: 519-6315800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:06-FEB-2002 Doc #:11007203 Tech Comments: INSPECT ALL SEAT BELTS ALL PASSED 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 10 7S20 180103 * 14A630 * S15 28 34488 AWS Claim Key: 7097464 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: A8303 - * Name: TALBOT FORD LINCOLN SALES LIMITED Ph: 519-6315800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:06-FEB-2002 Doc #:11007204 Cust Comments: PLS C FOR DRIVERS POWER SEAT NOT WORKING AT THIS TIME Tech Comments: PIN TEST AND REPLACE FUSE 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 11 7S05 140103 * 14300 * D02 X2 36116 AWS Claim Key: 7255964 Trx Code: E83 Labor Hrs: 1.6
Dlr Cd-Sub Cd: A8303 - * Name: TALBOT FORD LINCOLN SALES LIMITED Ph: 519-6315800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:26-FEB-2002 Doc #:11070801 Cust Comments: VEHICLE TOWED IN WILL NOT START, WILL TURN OVER BUT NOT START Tech Comments: PIN TEST AND REPAIR WIRING, TEST GLOW PLUG OPERATION 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 11 5T03 110402 1C3Z 7210 AAA D41 B4 36824 AWS Claim Key: 7538140 Trx Code: E84 Labor Hrs: 3
Dlr Cd-Sub Cd: A8303 - * Name: TALBOT FORD LINCOLN SALES LIMITED Ph: 519-6315800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:06-MAR-2002 Doc #:11094901 Cust Comments: REPORT ON LACK OF POWER WHEN BRAKE DEPRESSED AND VEH PUT INTO GEAR Tech Comments: ACCESS INTRUMENT PANEL, DIAG, AND REPLACE GEAR SELECTOR LEVER 1FTNW21F91EC30630 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 26-FEB-2001 17-APR-2001 4B8158 CAN 17 3A11 070100 1C3Z 7000 FBRM P51 30 46825 AWS Claim Key: 10627198 Trx Code: Z06 Labor Hrs: 5.8
Dlr Cd-Sub Cd: B8158 - * Name: HIGHBURY FORD SALES LTD Ph: 519-4551800 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:19-AUG-2002 Doc #:24212501 Cust Comments: CUST REPORTS WHEN SHIFTING FROM 1ST GEAR TO 2ND GEAR RPM IS GOING TOO HIGH BEFORE IT SHIFTS, CUST HAS TO GO OFF THE GAS PEDAL TO LET THE TRANS SHIFT Tech Comments: THE INTERMEADIATE ONE WAY CLUTCH IS BROKEN IN THE TRANSMISSION. TRANS DIAG CODES P0781 P0732 PINPOINT TEST REPLACE TRANS ASSY FLUSH COOLER AND INSTALL FILTER. CASE # 475821552
hmm. It seems to have had all the problems when new. Nothing since 2002. but that could mean they stopped taking it to the dealer. :dunno: Doesn't seem like anything major though, Just some small repairs..
no,just small stuff it seems to me
So I'm guessing its a good thing this tranny was rebuilt. I read on here that the 2001 transmissions wre notoriois for problems, something about the mech diode problem????
1 - 5 of 5 Posts
