1 - 20 of 32 Posts
I have read several posts were people have installed O3 turbos as an upgrade, need someone to explain what the differance is. Thanks
the main reason is for the insane whistle 03 turbos make:thumb:
dont quote me on these numbers but i believe the 03 turbo is 10 vane the 04 turbo is 12 vane and the 05-07 turbo is 14 vane the more vanes the quieter the turbo whine is straight piped the 03 turbo sounds like a jet plane taking off almost lol :icon_ford:
03 is 10 Blade, 04 is 12 blade, and 05+ is 15 blade. I put one on my 06 this weekend and yes the whistle is great, it has a tiny bit more lag off the line, but IMO pushes more ar quicker so when it hits it is alot quicker. I also build boost faster at a roll... Did I mention the whistle?? lol
The early build dates of the 2004's came with the 03 Turbo. Check your build date, you may be lucky.
I WANT ONE BADDDD, no money right now though :(
I finally found one. I should have mine installed this weekend sometime!
Ahhh, to have an 03 Turbo :D You'll be able to tell if you have a 03...Specially if you got it piped. jared, what is your build date?
Look on the door inside door frame
Whats the " latest" early 04 build date , or should i say what would ne the build dates to have a 03 turbo.
I believe it was mid to late Oct. or Nov. Somebody with better knowledge should chime in.
I believe it was November
9/29/03 is what I was told and its my trucks build date. The 03 turbo is suppost to push about 50 more ponies than the 05+ turbo. And did anyone mention the whistle??? Lol jk
what if you replace a 02 turbo on a 7.3l with a 03 turbo?
1 - 20 of 32 Posts
