So my truck is wanting to charge at an idle when you first start it up and until you start driving it and sometimes takes a mile to get up to 13v on my cts. The alternator is only about 3 weeks old and batteries were new last april and the alternator is a 139 amp. I went with the bigger one because i went threw 3 110 amps in 24 months. The only aftermarket electronic item i have in hid headlights and i pulled the fuse out on them and it didnt change anything. The only other thing im thinking is the posative cable on the drivers side looked like it has oxidation in the end of the wire so i sprayed the terminal cleaners in the end and waited and hour washed it off and started my truck and it was charging 13.3 so i plugged my hid's back in and turned them on and it went up to 13.5 and now today its back to not charging till im driving again. I wouldnt be to worried but when its not charging my ficm is reading arounf 42v and its a 58v swamps ficm. And my voltage will read 11-11.5 till it starts charging. I have unhooked my batteries and voltage and load tested them and the voltage held at 12.6 when they were unhooked and load tested fine i beleive they are 1000 cold cranking amp batteries. It sounds like the wire might be corroded to me but is there a way to test it? And could that make my truck not start charging till im driving
