1 - 2 of 2 Posts
When I connect my trailer plug to the truck I'm only getting the trailer lights on. I am not getting any power at the plug for both the left and right turn signal. I'm not getting any power for the brake lights either at the plug. I checked all fuses and there is no problem there. All the lights on the truck are working good. Is there something I'm missing? Please help!!
Did you check the fuses under the hood? If you did and they are good I would start going along the frame and checking the wiring I had a spot in mine where a gooseneck plug was hacked off and never covered back up and had to cut out a bunch of it.
1 - 2 of 2 Posts
