1 - 5 of 5 Posts
· Premium Member
perhaps pull the main light switch check that its sending the signal. you will need a multimeter
If everything is ok. then check the fuses again. Its unlikely that both items would fail together unless their both on the same circuit. hope this helps
· Registered
Did you check all the fuses under the hood as well as under the dash?
· Registered
I had this happen to me once as well. I had to replace the fuse for the OBDII port under my dash. I hope this helps.
1 - 5 of 5 Posts
