1 - 1 of 1 Posts
begining issue was white smoke,rough idle after warm up, last week i replaced 8 injectors , truck started and after warm up did the same white smoke, rough idle as before. I replaced the oil cooler, egr cooler. today all assembled, try to start and all i get is cranking with no sign of trying to start.
no tail pipe smoke , no sputter,, I lost some oil with the oil cooler replacement, I put 2 qts back in and im still not on the dip stick, im going out to get some more oil and add some more.low oil maybe ? interior gauge goes up when cranking, ill get oil add and pull the filter cap and filter and see if oil fills up rapidly when cranking .,
any other ideas?
1 - 1 of 1 Posts
